1971 Fuel pump question
Hi,
I have a 71 impala with a 400 small block, and I'm trying to locate a fuel pump.
The problem is that the fuel pump on the car is not like the ones availble from the local parts store.
The one on the car has 2 imputs with a larger housing, like a marine fuel pump. I think one of the lines is recovery return. My local Chevy dealer only shows parts as far back as 76.
I could put a regular pump on it but then I have an extra line to contend with.
Has anyone seen one of these before, and if so where can one be bought?
Thanks for all replies.
RE: 1971 Fuel pump question
http://www.napaonline.com/masterpage...echanical+Type)
^^^^ Check this link i think this is the pump your looking for. if you try to find it another parts store i put it in as a 1970 camaro with a 5.7L 350 with a 4bbl carb.
my 1970 Monte carlo has the same thing.
though at some point the previous owners simply put a bolt on the return line to cap it off.
in 19 yrs Ive had the car- its not been a problem.
I think it was some return line for unused fuel or something.
Twizzle12,
That's it exactly. I searched the napaonline as well as my local NAPA store and they had never seen one. Thanks.
rbarrious,
I had a 1978 Mark Twain boat with a 3L 4 cylinder GM engine that had a similar fuel pump. I thought it was used because if the diaphram failed then the bildge wounldn't fill up withfuel.
This car isa driver and I like to carry a few spare parts, so I wanted to able locate one. I figuired I could buy any Chevy small block pump and make it work. I'm just picking about having correct parts.
Thanks again for all replies.
rbarrious,
mangomanj
August 17th, 2014 9:51 PM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
