2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2005 Impala Passlock Problem
Old May 14, 2010 | 6:30 PM
Ernie's Avatar
Default 2005 Impala Passlock Problem
I had a problem that this car would not start at various times and I would have to wait 10 minutes and it would start and run fine this problem kept getting worse. I took it to dealer and they replaced the BCM for $400.00 that very afternoon the same thing happened. I then went on line and thanks to all your information when I returned to the dealer they replaced the sensor and cylinder at no cost we will now see what happens. I must say I am very pleased with Medved Chevrolet in Colorado they have always backed thier products.
Old May 15, 2010 | 6:41 AM
capucine's Avatar
Had the same problem with my 03 impala. The sensor on the key cylinder was the culprit. I wish they would have run a recall for this problem that could end in a safety issue. Exemple ( you have to drive someone to the hospital and the car is dead ) For us we were more lucky. We were stuck in a strawberry field after picked up our own berries and the car would not start. It was so upset with this problem that I was ready to scrap the car because of this no nonsense issue. I dont count how many times it happened to us including the time when I filled up the gas tank and the car had to be pushed out of the way for the others that were behind.
Old Apr 2, 2013 | 12:40 PM
coeleigh's Avatar
My 2005 has recently starting doing this, along with a whole bunch of other things that are going down hill with it.
Old May 30, 2013 | 7:48 AM
llafuente's Avatar
I have an 05, and have had the same problem. I found, at a chevy forum, that it was in the passlock. Chevy used tin in the connector and the tin will corrode. The fix was easy and cheep; put some DIELECTRIC grease on the contact. I have not had the problem since, and it's been about 4 months. It was a bit difficult to take the lower part of the dash apart but the total was about $4. Now all I have to do is figure out why my gauges won't work.
highway32south
Jul 28, 2014 1:26 PM
ecir80
May 23, 2012 9:24 PM
tonynikki0181
Jan 15, 2010 10:56 AM
