-   Impala (https://chevroletforum.com/forum/impala-14/)
-   -   2006 Impala... Pedal Position Sensor or TPS?? (https://chevroletforum.com/forum/impala-14/2006-impala-pedal-position-sensor-tps-48176/)
Saskatoon_Jim Jan 27, 2012 11:02 PM
I really need some help on this one... So I get "Traction Service Control" msg, then "power is reduced" msg comes next and now car shaking and coughing in limp mode. So I change Pedal Position Sensor(basically your gas pedal) easy to change! Still the same thing happens... But now car will quit and "Starter disabled Service Throttle" msg appears, What the duce!!! I did replace the throttle body about year ago, when I got this message. So I'm assuming the TPS is still the original one. I understand that TPS plugs into throttle body?? I did unplug battery overnight before plugging in new Pedal. I haven't checked the codes yet, but from what I've seen posted about this problem I thought it would be an easy fix... So if anyone can shed some light on this please do!! :confused:
EinST Jan 28, 2012 12:03 PM
Welcome to the forum.:) Where's the "neither" option? The TC requires pretty much everything on the vehicle to work right that has to do with powertrain and braking.
