2007 large leak (P0445)
I have checked the gas cap and cleaned off the rubber on the surround. I removed the EVAP canister purge solenoid valve and canister and tried to clean that out. I have also checked all the lines I could find. Can I manually check the valve with a 12v source? And is there a selenoid i can check and where is it? Any advice would be appreciated.
http://www.bba-reman.com/content.asp...NEXT_DTC_P0445
Mike Alpha
May 31, 2015 1:38 PM
Bookscout
Jun 11, 2008 6:38 AM
biglg
Nov 29, 2006 12:50 AM
