2011 vvt selenoid(cam magnet wiring diagram
Hi Sheldon,
Can we ask how it was determined there is a short in the wiring, unless you are just using this term loosely?
If the answer is unclear , you could be going on a wild goose chase.
There are other things you could check, good possibility it could be mechanical, maybe doing some research on the things that cause that code to come up for instance.
