-   Impala (https://chevroletforum.com/forum/impala-14/)
-   -   2015 Impala code P0442 (https://chevroletforum.com/forum/impala-14/2015-impala-code-p0442-89331/)
BobHorn Mar 5, 2018 4:21 PM
Got the above code (Small Emissions Leak). Changed gas cap, no help. Any thoughts about obvious things to check?
Thanks,
Bob
Esteban Aldama Mar 17, 2018 9:21 AM
pumping gas.
Hey bob, does this happen when you pump gas? Have you tried to reboot the car system sometimes all it need is a reboot to stock. I to have a similar problem with the gas cap. I had my cars system checked twice for problems and had nothing wrong came up except that I needed a new gas tank cap some thing wrong with the sensor but when I did change it problem is still there so. Ow that every time I pump gas my car won’t start after two or three times battery is still good, everything in the cabin still functions any help would be nice thnx. It’s a 2015 model, oh I also checked vin numb. For recalls and nothing came up.
Thanks,
Bob
tech2 Mar 17, 2018 10:14 AM
if the vehicle won't start after filling with fuel; have the purge valve checked. If the purge valve is stuck open, fumes from the filling event will create a flood condition and cause a hard start.
