3800 Series II Motor: What is this?
Hi there. I am new to this forum. A proud owner of a 2003 Chevrolet Impala LS.
I believe this may be some sort of vacuum line, but I'm not sure. Here is a picture below. (Not my motor.) It has a little tear in it, big enough to display a "check engine" light on the dash. Any help would be appreciated.https://cimg2.ibsrv.net/gimg/chevrol...85d5b9b3ee.jpg |
vacuum port for the fuel pressure regulator and evap purge solenoid. if its cracked you will get lean codes setting at idle. replace part.
Thank you for the response. I have one ordered.
Mine was cracked as well causing issues. I put a glob of RTV over it and left it dry before I ran the car again. It held up until the replacement arrived at my dealer.
Do you only have codes p0171 and p0174 for the check engine light?
