ANY NEW NEWS ON THE REMOTE CONTROL PROBLEM??
#11
RE: ANY NEW NEWS ON THE REMOTE CONTROL PROBLEM??
My dealer said the reciever (which is the root cause of the problem) is on national backorder. You should check w/ your dealer to see if THEY have it, because noboday else does! In the meanwhile, I will continue to park right up against my house for best range...all 20 feet of it!
#12
Thanks for the helpful info OHSEVENLTZ, I'm going to print this and take to my dealer and see what they can then do.
#13
i work in a parts dept. at a chevy dealer
and the part is on national backorder
we got a few people waiting for this part
good luck
good luck
#14
what is the expected wait time for this part? are they coming out with a redesign? Because obviously the first one failed, i dont want to go through all of this headache to put in the same part, and after 2 monthes, be back in the same situation!
#15
My dealer just called and said the parts were in and I have an service appointment on Thursday. Another thing is that my Tire Pressure monitor started actring up yesterday too. I hope this transmitter fixes this problem as well. I'll let you all know how it goes.
#16
I have a new 2007 Impala S/S with the same remote start problems. My chevy dealer said he ordered all three parts; installed them and the range at best is 40 feet. The remote did not work at all when I first bought the car in Febuary. The dealer does not no what else to do to get the 200 advertised feet the manual says. Any other suggestions?
#17
did he order the updated parts? could be a bad replacement part?
The build date on our 07 3LT is Feb 12, 2007- so it seems the new cars are getting the updated parts, I tested the distance -went to an empty parking lot- and walked across lot- and tried to remote start the car and simply lock the car- from quite a distance I was able to do it. Too bad I didnt measure it. (i should try with my GPS)
But Id say it was 200 feet PLUS. Distance is a bit longer when you put the remote to your chin and press the button... try it... it works.
#18
Hey guys- I have an 07. Build date of Feb 12, 2007.
I went out to an empty lot. walked across to the other side- pressed the lock button- nothing- placed remote on my chin- and lights came on.
Neat...
So I turn on my Garmin GPS device- walk back to car while pressing the lock button- remote about waist level.... then lights come on... heres the distance.
remote on chin- 400 ft.
remote at normal waist level- 300ft.
Neat...
#19
Had my ImpalaSS in the shop again for the short distancethat the remote would work and the mechanic found a service bulletin that stated not to replace any parts on the car, but do replace the key fobs (remote controls). They ordered me 2 new ones, so I will see what happens when they come in. Anybody else heard this from your dealer?
#20
do you know the data on that service bulletin?
I think the fix for this is to replace the parts..... unless this is a new up to date tsb.
