Crank NO SPARK Help
Crank NO SPARK Help
2005 Impala 3400 V-6
Engine cranks fine. ALL fuses are good. ALL relays are good and working as they should. No Spark at plugs. No OBDII codes. Any idea where to start? Please guys, I am very well versed in electrical and I assure you the fuses and relays are as they should be so I really don't need, "did you check this fuse or relay".
