Jumping 2002 Driver Window Switch
My switch in my 2002 driver's side door is dead for the window. The auto-shop want's $200 alone just for the master switch block. I'm not really worried about getting it replaced right now but the problem is is that my window is stuck down. I was curious if there is a way to jump the wires via one of the plugs going into the switch block. There are two plugs going into the master switch block, a blue plugged one and a red plugged one, and I'm pretty sure the red one is the one I should be looking at. I just don't know which wires I need to jump in order for the switch window to go up. Any ideas?
Welcome to the forum. Assuming that the window regulator assembly and wiring are okay, apply 12V to the DK BLU wire (master switch connector C2, pin C) and ground to BRN wire (connector C2, pin D) to turn the motor in the window-up direction. Tap into the YEL wire (connector C1, pin B) with a fused jumper wire for 12V.
Desp
October 3rd, 2016 7:06 AM
rafter
September 1st, 2014 9:17 AM
kevinryan87
April 17th, 2014 7:21 AM
thegrove45
November 19th, 2007 8:20 AM
