2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
no blinkers/ hazards 2002 impala
Old May 12, 2007 | 10:58 AM
mlg's Avatar
mlg
Default no blinkers/ hazards 2002 impala
[]Sombody please help I need to pass inspection and I havent had blinkers or hazards at all for months now, cant afford to take it to the dealership. Already checked fuses, and bought a manual, but still confused. Please help.
Old May 16, 2007 | 6:10 PM
hillbilleous's Avatar
Default RE: no blinkers/ hazards 2002 impala
9 times out of 10 it is the signal/hazard switch that goes bad. I have replaced several before and it solves the problem. you will need a special tool to remove the steering wheel. almost imposible without it
Old May 17, 2007 | 8:27 AM
mlg's Avatar
mlg
Thanx so much for replying I am trying to be the independent woman but its hard Remove the whole steering wheel or just the front piece? In the book it says something about the front cover of the wheel, is that what you are talking about? Thanks again for the advice.
Old May 19, 2007 | 8:07 PM
JHH's Avatar
JHH
I think the hazard switch also. But I thought that it was on the dash on those cars. Just went out and looked at moms car and it is on the dash on the right of the steering wheel. Replace that or push it repeatedly and sometimes they will start to work. I have also seen the multifunction switch go bad and you would have to pull the wheel to replace it. JHH
Old May 20, 2007 | 9:25 AM
two slow's Avatar
Do they still use turn signal flasher on these vehicles? Thats what it sounds like to me, especially when both turn signals and warning flashers go bad at thew same time.
Old May 20, 2007 | 12:14 PM
JHH's Avatar
JHH
flasher is built into the hazard switch now. JHH
Old May 21, 2007 | 9:13 AM
golfer's Avatar
There was a recall for the Malibu through to the 02 model year for the hazard switch. The symptom was intermittant or no hazard / turn flashers now whether or not this affects the Impala is not certain.
I don't believe the flasher circiut is built into the hazard switch rather the wiring for the turn and hazards are at a common point to the hazard switch circiut board and go on to the flasher unit.
Jakester
14
Jun 15, 2023 11:38 AM
Got Options?
Jun 20, 2013 10:24 AM
Lymsleia
Aug 14, 2011 10:48 PM
Manor_Mullet
Apr 28, 2008 2:13 PM
dstedman
Sep 9, 2007 10:24 AM
