No Cruise control
1 Post
No Cruise control
My 2000 Impala's cruise control has stopped working. Completly non-responsive. When I hit the cruise switch on the blinker handle, then push the cruise set button on the steering wheel, the cruise control system does not come on. The cruise light on the dashboard does not come on either. Does anyone know what could be up?
I suppose it could just be the switch. You'd have to replace the whole multifunction switch to fix it though. I got a new one for my 2003 off ebay for $50; that was to fix my brights. Not a difficult install. Then there's the cruise control switch behind the brake pedal but I think your cruise light would still come on if it were bad. But I don't recommend just replacing parts. Best is get a multimeter and wiring diagram and see where you have and don't have power and ground.
If I remember correctly, the cruise control on my 2001 Impala stopped working when I got an anti lock brake light on the dash. When I replaced the front right wheel bearing, the light went out and the cruise started working again.
