no onstar no bluetooth and no xm
just bought 2010 chevy impala have looked at these cars for a few months now and decided to buy one, bought it used from a non chevy dealer. acura only 34,000 mi. did not need to buy anything my current car which i kept is just fine, just outdated i wanted some of the modern conveinences like bluetooth and xm radio did not have to have onstar but i am learning that my car was a fleet car and thats ok it was well taken care of but appearantly if built to be fleet car they do not install the onstar hardware which is required to use the other features :( dont know what to do it is not what i wanted
any suggestions would be appreaciated thank you |
Originally Posted by y2kpa2
(Post 191810)
If you do not have onstar then you won't have bluetooth even if the button is there.
You can go to Best Buy and purchase Onstar and have the bluetooth capability. GM started that a few months ago. It is about 350 installed. Kevin was right, xm is xm and radio should have the id code so that you can activate it. |
i cannot tune to channel 0 for radio id i have followed directions to do so it only has am fm channels if you press the (CAT) button it says XM FEATURE but if you turn the smaller dial it tunes am or fm:confused:
(Post 191828)
If ordered on fleet, the OnStar delete and XM delete features go together. Those two components share the stubby antenna on the roof and thus there's no reason they'd leave the XM-capable radio in when the antenna gets deleted. It sounds like a serious case of buyer's remorse. Some states have laws that allow the buyer to get out the deal within a few days of the sale.
the radio is the correct one for xm and the steering wheel controls are correct for bluetooth but i also noticed there should be a microphone above rear view mirror, mine does not have that????
The steering wheel-mounted audio controls are just that. The Bluetooth-looking controls and markings don't mean anything since they all look the same, with or without Bluetooth. As for your statement "the radio is the correct one for xm," I guess I'll take your word for it. Good luck.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> @y2kpa2, if you would like to provide me with your VIN, I would be happy to research your build history of your vehicle. By me doing this, it could possibly tell us when you don't have bluetooth, XM radio and no OnStar.
Michelle, GM Customer Service |
to Michell @GM , can you post your email so I can send you my VIN? I have the same XM problem in my 2010 Impala. My on-star is activated, but I cannot find a solution to my XM "Feature" problem.
