2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
P2440 Code-Please help
Old May 2, 2013 | 2:42 PM
impala184's Avatar
Question P2440 Code-Please help
Please help
I have a 2008 Chevy Impala LT 3.4 V6. I recently tarted receiving a engine Light and a coworkorder ran the light and came up with "P2440 secondary air injection system switching valve stuck open (Bank 1)" What causes this and how can I get it fixed?
Thank you in advance
Old May 2, 2013 | 8:09 PM
Brok's Avatar
Secondary AIR System Switching Valve A' Stuck Open - With Automatic Transmission
Possible Causes Setting Conditions
  • AIR pump connector is damaged (check pins for damage, and for moisture)
  • AIR pump relay coil control circuit is shorted to ground
  • AIR pump solenoid power (12v) circuit is shorted to voltage
  • AIR pump relay switch supply circuit is open or shorted to ground
  • ECM has failed
  • codes refer to emission & should be covered under factory warranty
  • Good luck
rodes6
Cobalt
Dec 10, 2013 8:53 PM
beezey
Nov 24, 2011 4:01 PM
