Last edit by: IB Advertising
Browse all: Engine and Powertrian
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Thermostat
Thermostat Replacement
Hello Chevy Impala Owner's
I have a 2003 Impala with a 3.8L V6 engine and i would like to know do anyone have any step by step instructions on how to replace the thermostat
, I appreciate everyone's time...Thank you
You can follow these steps:
* Locate the top radiator hose and trace it to the location where the hose is connected to the Impala's engine. Remove the clamp that holds the hose onto the cover with a screwdriver.
* Remove the thermostat cover by removing the two bolts that hold the cover onto the intake manifold. Locate the thermostat cover gasket and remove it.
* You can easily remove the thermostat from the inside of the intake manifold by pulling directly up on it.
* Place the new thermostat into the intake manifold with the correct end facing out of the intake then, place the new gasket onto the intake manifold and replace the thermostat cover
rainman89
Jan 2, 2014 8:20 PM
vofsar
Dec 22, 2005 12:32 PM
vofsar
