-   Impala (https://chevroletforum.com/forum/impala-14/)
-   -   Transmission problem 2004 Impala (https://chevroletforum.com/forum/impala-14/transmission-problem-2004-impala-5146/)
TMAN Jan 31, 2007 4:21 PM
My 2004 Impala has 86k mileswith anintermittent trans problem. Symptoms are hard shift threw all gears on acceleration. I have read that the older 00-03 Impala's have some issues with the pressure control solenoid. Does anyone know if that holds true for the 04 model year? Is this a job a back yard mechanic can handle?
golfer Feb 1, 2007 12:56 AM
RE: Transmission problem 2004 Impala
There is also a problem with debris in the valve passages... do you think this is backyard project?
TMAN Feb 3, 2007 4:51 PM
If it is as easy as changing brakes,motoroil and filter than yes thisback yard mechanic could do it.If it involved special tools or removing the trans from the car I wouldn't bother. The local shops here inOhio change$180- $260 to change theoil filter and gasket on the trans. I know a mechanic friend, unfortunately in another state, that says it costs $30for the kit plus oil and takes about 1hr. So I would hate to see what it would cost for anything more.
golfer Feb 4, 2007 9:13 PM
If you have to do things like removing the valve body you certainly don't want dust and grime inside the tranny.
It's not like changing the brakes or an oil / filter change that's why I say ... do you think it's a backyard mechanic job ??
New02 Feb 21, 2007 7:13 PM
I have an 02 Impala LS with 88,000 miles. It shifts hard during acceleration sometimes too. After the trans heats up a little then it starts. Let me know if you found a fix for it and how much $$$are we talking.
