Chevrolet Malibu
2004-2007 Headlight Fire Hazard
Old Jul 31, 2008 | 3:19 PM
  #11
Leadfoot's Avatar
Default RE: 2004-2007 Headlight Fire Hazard
Now I would have hoped that GM would have taken this more seriously but all my dealer told me to do was call them. I called them and they didnt even bother to look at the car to see the damage before they said that they wouldnt cover it. Now it says here you are a GM tech. Have you looked at any malibu's to see the problem?
And if you take a look at the nthsa's website you will see other reports of this as well
Old Jul 31, 2008 | 3:20 PM
  #12
Leadfoot's Avatar
Sorry for having to draw it out in seperate posts but this forum is not letting me post it all at once.
Old Aug 1, 2008 | 1:20 PM
  #13
colbuzz's Avatar
I also have this problem with my 2005 Malibu. Went to my dealership to find out if there is a different bulb that i could use. No help!
Old Aug 2, 2008 | 12:01 AM
  #14
chevy=fun's Avatar
How many miles are on the vehicles when this was notice...
Old Aug 2, 2008 | 10:51 AM
  #15
slls's Avatar
The problem is mostly in high temp climates, 35 K on mine in the rust belt , no problem.
Old Aug 2, 2008 | 4:12 PM
  #16
colbuzz's Avatar
Less than 50000 on mine and i live in the midwest.
Old Aug 3, 2008 | 9:38 AM
  #17
slls's Avatar
Must get hot in the mid west, we had one 90 deg day so far this summmer.
Old Aug 4, 2008 | 9:35 PM
  #18
shawnvw's Avatar
Banned
why don't you light fire to the car, blame it on the headlight assy, and sue the pants off of GM. Maybe someone will listen to you then
Old Aug 10, 2008 | 12:46 AM
  #19
yofa's Avatar
don't be so hard on the guy. he's right. these headlamp assemblies fail prematurely. both of mine on an '04 maxx need replacement. i'm at 80 000 km (50 000 mi). the amber lamp shroud overheats, melts, drips onto the lamp connector and shorts it out. replacing the bulb doesn't fix it, and it leaves a burnt area around the amber lamp.
only fix is to replace the whole headlamp unit, or the connector and shroud if you could piece that together. but then it's just a matter of time until it does it again. the critical difference betweenmine and the original poster'scases, and most other readers here, is that our cars have canadian drl's, which work off the high-intensity side marker bulbs. not sure if it's the same for you guys, but judging from the one headlamp assembly i ebay'd up from the states, i don't think you guys are running front side markers drl's. i think chevy didn't properly engineer it for canadian duty cycles.
fire hazzard warning may be extreme, but inoperable turn signals is not a good thing either.
anyway, anybody got a fix? other than replacing the unit every couple of years?
Old Aug 10, 2008 | 11:07 AM
  #20
slls's Avatar
I checked mine when I had bulb connection problems. The DRL on my US car is using the parking lamp, I was surprised, I thought it was the turn lamp. No melting just the bulb connection high resistance.
