Best repair manual
From what I hear; Haynes is better then Chilton. Either way, I've seen incorrect torque specs from both. I recommend that you try to get a GM repair manual off of Ebay. Sure it's much more but at least you are getting the proper information. Depending on how in dept you are would probably be a good indication on which to get. If you are not going to tear the engine down one day, then Haynes will probably suffice.
I'll agree with that. I've owned plenty of cars over the years and got a Haynes for most of them. If you want to save a fortune on car maintenance and repairs, can tell the difference between a wrench and a hammer then they are worth their weight in gold.
Wakko
Avalanche
November 21st, 2013 10:04 AM
maxvision
May 20th, 2010 10:08 PM
