Computer Info Display
2012 Malibu LTZ 3.6 V-6 engine
On the dashboard beneath the speedometer is the computer digital information display readout.
Can the readout be manipulated to display values/messages other than the factory default?
Since I live in Kuwait, I would like to change degrees in C to show in F, and tire pressures to PSI. Also, once the car speed hits 120 kilometers per hour as a default, the display will show 'OVERSPEED' and locks out all other functions until under that 120 target. I dont care if it actually displays, but to lock out all other data should not happen. At times the overspeed display will also display and lock out prior to actually hitting the target of 120.
Any suggestions?
Thanks
Any suggestions?
Thanks
There's no secret backdoor. The DIC personalization topic is discussed in section 5 of the owner manual. As for the top speed, the ECM includes a governor/limiter function based on, among other things, the engine RPM and speed rating of the factory tires. Before you ask, no, I don't think it can be reprogrammed.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> GuidoGuacamole,
EinST is correct. The only personalization options are listed in the owner's manual, pages 5-29 through 5-33. A digital copy of the manual is available at: http://www.chevrolet.com/assets/pdf/...2k12malibu.pdf
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> GuidoGuacamole,EinST is correct. The only personalization options are listed in the owner's manual, pages 5-29 through 5-33. A digital copy of the manual is available at: http://www.chevrolet.com/assets/pdf/...2k12malibu.pdf
Louis
GM Customer Service
adamant
Feb 17, 2009 2:54 PM
