Chevrolet Malibu
Idle and load problems
Old Oct 25, 2008 | 9:45 PM
tornado229's Avatar
Default Idle and load problems
Okay my Wife's car (2001 Malibu) had been doing this for a while now. When ever you have drove it and come to a stop the engine jerks kind of like it is misfiring. It has no pattern just when it wants to. Now whenever it goes up hill and gets to about 2000 rpm it jerks like it is missing again and whenever it is doing this the check engine light blinks but then goes off after the hill. No error codes or nothing. Maybe I can change the fuel filter and clean the injectors. Just had new plugs put in. New EGR and CAT 1 year ago. New O2 sensor about 5 months ago. Has always been a dependable car. ANy ideas? Thanks.
Old Jul 12, 2010 | 12:19 PM
jayboog5000's Avatar
Default my car has a similar problem
my wifes 2002 malibu has a very similar problem when under a heavy load or when the ac is on the car will buck and misfire and is will not idle very long without stalling i have been at this for a while the scan tool says the 3x low resolution engine speed is way off the readout looks like a slot machine spining with random numbers when the problem occurs I have verified this with my meter on HZ and i can see the signal jumps way up to double the speed it should be when the problem occurs I have already replaced the cam and crank sensors the problem is the same going into the ignition module and coming out so i thougt it must be the crank sensor but no luck this is driving me mad have you figured anything out?
jaysranger
May 9, 2015 3:10 PM
prowe3
11
Dec 17, 2012 4:48 PM
dbass
Jul 22, 2012 9:05 AM
86silver
Mar 9, 2012 5:57 PM
rteas48183
Mar 18, 2008 4:59 PM
