No air hot or cold coming through vents
My 2009 Chevy Malibu 2.4L LS manual climate control HVAC system has been acting up. The blower motor seems to be intermittent. Air was coming through vents, then cut out on driving down the road. The air quickly started back through the vents. A couple days later I went to turn on the AC and no air was coming through vents period. It has been 4 days now and still no air flow. The three mini fuses and HVAC relay in the passenger side cab were inspected and tested. They were all good, I replaced them anyways. The AC fuse and relay under the hood was tested and was good. I took out the blower motor and used a power probe on it and is functional. The blower motor resistor was tested with a multi meter. The negative lead on the 1st pin and the positive on the 2nd 3rd and 4th pins. The readings in Ohms were 0.5 0.7 and 1.6. This seemed low as i have read the range is 2-3 Ohms for a working resistor. I replaced the resistor and powered up the vehicle. The blower motor turned on at a high speed and then died shortly after. It will not turn back on. My next thought is the climate control unit is faulty. I tested the fan speed portion of the climate control unit and did not get any voltage period with the car turned on. There was power and ground to the temperature switch connector. The defroster and recirculation buttons do not light us as they should. My thought is the unit itself is bad (circuit board in the unit) or the connector is not getting power. I don't know what the next step should be. Any help or suggestions would be very appreciated. Thank you,
Checked all the fuses again, all had voltage. Climate control unit powered on today randomly, blower motor worked. I went through the 4 fan speeds and it turned off as soon as I went to the highest speed.
amerino28
September 16th, 2023 5:42 PM
Cableguy216
2007 - 2013 (GMT900)
August 2nd, 2019 2:07 PM
bates2121
June 17th, 2011 4:20 PM
