Chevrolet Malibu
P0240 Code - Need Help - Don't Know What Issue Is
Old Jun 13, 2012 | 11:27 PM
tloestreich's Avatar
Default P0240 Code - Need Help - Don't Know What Issue Is
I've been chasing this issue for a while, and I'm not sure where to go next.
Some background:
The fuel pump went out in the car last September and it was replaced. Shortly there after, the check engine light came on and we replaced the gas cap which seemed to fix the issue short term. The light came on again in October. The car passed the emissions test in November. The check engine light hasn't affected how the car has run at all, so I haven't addressed the issue since. I'm now looking to sell the vehicle and would like to fix the issue assuming it doesn't break the bank.
I took the Malibu to an AutoZone and had it scanned. I attached the results from the scan. The code that came up doesn't seem to be a very common code.
Code: P0240
Description: The PCM has determined that the input voltage for boost pressure sensor "B" is out of range for the current engine operation conditions.
Any help is much appreciated.
Attached Thumbnails P0240 Code - Need Help - Don't Know What Issue Is-p0240.jpg
Old Jun 14, 2012 | 6:30 AM
johntaps's Avatar
Former Sponsor
P0240: The PCM has determined that the input voltage for boost pressure sensor "B" is out of range for the current engine operation conditions.
Is this correct? I think 05 Malibu do not have Turbocharger and BTW this code is stands for Catalyst System Efficiency Below Threshold. So please reset the code once, remove battery terminal and then again check whether code pops up or not. Go for chevy dealer.
Old Jun 14, 2012 | 10:42 AM
Thanks for the suggestion. I'll give it a try and let you know what I find out.
Old Jun 14, 2012 | 10:45 AM
Only other thing I can think of is that the code is actually referencing the amount of voltage going through the vehicle and that the alternator or voltage regulator might be bad. I have had to change the passenger side turn signal light a few times because the bulb goes out. When I replace it the connector is melted a little bit making me think that it could be getting too much voltage.
reecew1
May 5, 2010 6:09 PM
dleonard2844
Nov 29, 2007 11:51 PM
tahoelovah
Oct 13, 2007 11:25 PM
mandiebj
Feb 9, 2006 10:52 AM
