Weird power window problem
Ok guys here it is, 2007 Malibu Maxx, the power windows are not working with the drivers door closed. There is no power to the main wire at the master window switch. Once the drivers door is opened, the wire has power and all the windows work properly. Once you close the door again, the power is gone and the windows no longer work. The problem must be somewhere in the door, probably where the wires go from the door to the cab, somewhere inside the boot I'm assuming. Has anyone else seen or heard of this problem? Thanks for any help.
Tlindsey099
Oct 7, 2013 10:36 PM
davbell22602
Mar 10, 2010 8:36 PM
