1995 Lumina Won't Start & Low Volts?
Hey everyone, I'm glad I found this forum. My mother has a 1995 Chevy Lumina car with a 3.1L. It is having a few problems. The check engine light is on, and the "volts" light is on. The car won't start. It seems like it wants to crank over, but it just won't run. The alternator, ignition coil, spark plugs, and wires have been changed. I can't get it to a shop, because it won't run, and I'd like to fix it myself.
I was thinking maybe the battery, but all the lights turn on, keyless entry works, ect. And it seems like it wants to start, but simply can't run. Does anyone have any thoughts on what it may be? Any help would be greatly appreciated! |
Whats your distributor cap and rotor look like? Does it turn over without hesistation? If it keeps turning over battery is prolly fine. Try to take your plug out and see if your getting spark (safely) then report back.
Ok, I'm not sure what you mean by the dist. cap & rotor, I don't think the car has one, it has coil packs, though. Here is what has been done to it, that I know of:
(the service engine light & "volts" light were on) Spark plugs Wires Alternator Crankshaft position sensor (the one behind the harmonic balancer) I have tried: Coil packs Crankshaft position sensor (the one in the back of the engine, closer to the firewall) The "service engine" light went out after I did the sensor, but the "volts" light is still on. When I turn the key to the "on" position, I can hear the fuel pump prime itself. The engine will start and run for about 5 seconds, after it sits for a couple hours. If I try to start it again after that, it seems like it wants to crank over, but just can't run. Any ideas or suggestions would be greatly appreciated |
