Platform: A-, G-, & W-body
97 Lumina 3.1 No Spark
Old Feb 4, 2018 | 5:24 PM
97Lumina's Avatar
Exclamation 97 Lumina 3.1 No Spark
Hello. Having some problems with my 97 Lumina with the 3.1 v6. Theres no spark. So far i have replaced the crankshaft position sensor and ignition control module with no luck. There is 12v getting to the icm. I also repaired the ckp sensor harness and checked to make sure it has no resistance. Coil packs are tested and good and have done a compression test and got 150psi on all cylinders. Im running out of ideas. Thinking maybe its the ECU?
Old Feb 5, 2018 | 9:09 AM
kevinkpk's Avatar
Try the pcm first. I've replaced my ecm twice since I've owned. Is there any sel light/code? I had issue with my 96 just dieing, would show PO102 maf off performance, that was due to the ecm shutting off the engine. Would not restart until i erased the code. It might run two weeks, or two hours. Look at ebay for an ecm if need be. I bought the last one, no core with (sent the guy the vin) programmed for $70
Old Feb 8, 2018 | 2:04 PM
97Lumina's Avatar
Just to confirm pcm=ecm right? Not 2 separate ones? Do you remember where you got the one for $70? Did it need additional programming once on the vehicle? Also there's no check engine lights.
