Platform: A-, G-, & W-body
99 LUMINA Hiccups, volt light flashes I'm stumped
Old March 21st, 2018 | 10:19 AM
  #11
Slim Jim's Avatar
GM mode 6 reference chart pdf
This will explain the code info you got from it.
but your info is in hexidecimal form, try googling your output one code at a time.
heres another
Old March 24th, 2018 | 8:40 PM
  #12
FOWL1's Avatar
Default 99 LUMINA Hiccups, volt light flashes I'm stumped
Well the stumping is over. I had low fuel pressure so I dropped the tank & replaced the fuel pump. That did not fix the problem. I was looking at the car today and trying to figure what would make this thing stutter & stumble etc... after it was warmed up, but not trip the check engine light or throw a code for the scanner. The book had all kinds of suggestions, but they should have all thrown codes. Just out of curiousity, I took the PCV valve out and shook it. It did not rattle. I cleaned it with carb cleaner until rattled. I put it back in and took the car far a drive. I didn't think it was going to work, But guess what, it did. She runs fine now. Had her up to 80mph & no stumble or chugging etc... Who would have thought it, but that was the problem. Thanks to everyone who responded.
