mrl390 |
November 22nd, 2009 8:19 PM |
You will need to remove the back seat. Its easy, there are two 13mm bolts along the front edge of the seat bottom. Remove those, push the seat belt latches down through the seat and slide the seat bottom out. Then the seat back comes out if you take the 10mm bolts out. There are 3 along the bottom of the seat back. Fold the seat back down and there are two bolts under the felt that covers the edge of the hole from the cabin into the trunk. You need to unclip the felt from the sheetmetal and they are under there. Once they are out you can pull out the seat back. Then the rear deck panel slides forward and comes out. You need to slide the seat belts out of their slots in the rear deck panel. Once the deck panel is out, you can access the speakers. Remove the 4 7mm screws on each speaker, pull them out and unplug them. Done.
