THROTLE BODY SPACER
THROTLE BODY SPACER
I WAS JUST WONDERING IF ANY BODY HAS EVER PUT ATHROTTLE BODY SPACER ON THERE CAR AND THOUGHT IT WAS WORTH IT OR IT WAS NOT WORTH IT. THANKS FOR ANY INFO
RE: THROTLE BODY SPACER
i have never used one on any car. other ppl on the bourd have used them with no efect on the horspower of the motor at all.if i an find the thred i will post it here later.
I have never used one myself but a friend of mine, (keep in mind it's a different dngine) Said he got one for his 2000 Silverado with a 4.8 V8 and said it helped his gas mileage. I don't remeber if he thought he got more power or not.
I got a 91 c1500 extended cab p/u. I put a Air Raid spacer on it, and did notice better fuel mileage and better torque to tow. I also run full synthetic oil, K&N air filter, and NGK spark plugs and that really improved everything. The reason i use NGK spark plugs is because my brother had a 66 Chevelle that had a small block 406 in it and he kept fowling out other plugs and someone told him to try those and he never replaced another. I also used them in my motorhome and they worked great with the 454 big block.
Can anyone tell me what i need to convert the reardrum brakes on my 96 Lumina LS to disc brakes? I heard you could go to the junk yard and get the parts off a Monte Carlo to do it. Thanks.
Come on dude. Make you a new thread in the Monte Carlo section about your brakes and make a new thread and post about your truck in the Silverado section.
chevvy2000
October 9th, 2006 6:57 PM
