Blow by.....problem
Hello all I have a 1965 chevy impala convertible full show car lowrider....my problem is the engine....all seals are leaking and I have blow by my question is can it be fixed of do I have to replace the engine...any advice will be greatly appreciated
Does a 65 use a road draft tube or pcv system?
systems of blow by are oil in the air filter (if it uses a pcv system) and leaking seals. the fix for xs blowby past the piston rings...is teardown...measurements to determine the next steps. boring, honing, new rings. |
Thanks for your reply. I don't know if its PVC or other....so do you think I need to replace the engine of just get the rings done
if you answer my question...I can answer yours.
Hard to answer a question without knowing how its built. If there is a fault in the pcv system that could be the fix. If it uses a road draft tube...the pcv fix can't apply. |
