GM engine misfire question
Old June 8th, 2010 | 4:20 PM
firelt's Avatar
Default GM engine misfire question
I am new to this forum and have a 2002 gm van that is showing a misfire code P0300.
I have had this misfire code for some time only when I am accelerating and/or under load. Now the misfire code flashes whenever I pass 60 mph. I have never felt the engine running rough but a few times, but more recently I have. After an oil change it seems to stop the misfire until I am within the last 1000 miles of the 3000 between changes. I switched to full synthetic oil which seemed to stop it from misfiring the first 2 changes, but the last 1000 miles it has flashed every time I pass 60. I have had a complete tune-up. When I had it checked at a GM dealer early on (out of warranty) they wanted to remove the cylinder and check for binding in the valve. Then possibly machining the valve stem and hone the guide. Very expensive. I was advised that if it wasn't running rough and it only was happening infrequently not to worry about it.
Any ideas?
Old June 8th, 2010 | 4:48 PM
maxxman04's Avatar
have fuel pressure checked. v8 should be 60psi. if it's not 60psi, replace fuel filter, recheck. still not 60psi, fuel pump may need replaced, or fuel pressure regulator. also, change air filter if needed.
buddyleno
March 31st, 2017 9:13 AM
BBBTHATROCKS
19
August 9th, 2011 7:54 PM
Biggumzmcgee
November 15th, 2009 11:51 AM
lcottingim
October 16th, 2009 10:38 PM
Jeff1968
November 1st, 2007 4:35 PM
Quick Reply: GM engine misfire question
