View Poll Results: No power from ecu to fuel pump relay. Fuses all good. Help
Help
0%
Help
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Need help ecu
Need help ecu
Hi guy/girls
got a problem, I've got a 54 ford f100 with a chevy 5.3 swap. Several weeks ago I had a starting issue. The engine would crank but not start. I noticed the I didn't hear the fuel pump relay not click. I turned the ignition ket on and off then the relay clicked and engine started up. Figured it was the relay. Today went to start and the same thing happened, crank but no start. Went out and got a new relay, didn't help. Checked for power at the plug and discovered no power at the plug. I have power at the ignition switch but no power from the ECU to the relay harness. Desperately looking for help.
thanks in advance.
thanks in advance.
Welcome to the forum. You'll get more views by posting in Silverado or Tahoe sections as this is the Welcome New Members section.
Is there power to the ECU?
bigyance86
June 22nd, 2020 7:36 PM
Powelljames
November 11th, 2017 12:39 PM
