2wd-K5 |
January 26th, 2012 3:44 AM |
anything can happen if you make it. the olds engine needs the trans that came with it, you will also want the rad, and trans cooling lines as they are on the opposite sides as the chevy. measure tail shaft lengths on both trans and then mark off where the old tailshaft ends, then drop the new engine in to have the tailshafts ends. although if the tailshaft on trans A is longer than trans B, than it wont work, its all in the tail. the olds engine is big though, you may be happier just finding an old 350
