High compression 350 engine
I have a stock 74 nova police car 350 engine witch i am thinking of running those speed pro forged dome top pistons in it and that measures out as 11.5:1 with 75 cc heads. How would the stock bottom do with this and will it work? Can anyone please help me with this?
Regards Kjartan. |
if you plan on running 11:1 compression, plan on beefing up the bottom end. it may hold just fine, but if you're running compression that high obviously its being raced. 4 bolt main block, maybe new crank, BALANCING, this is important
Here is how I am going to help you.To buy only one pc of a big picture build is a kin to going back yrs ago of trial and error.That gets expensive is a hurry.
Compression is certainly a corner stone of what else you need to get. Remember the line of if you give a man a fish vs teach a man to fish??. I highly recommend you go on line and buy David Vizard's book on how to build hp for the SBC's engines.Read it cover to cover.Seriously.I mean that. If after that you have questions,post here and we will support you. You will find that will be one of the most important tools in your tool box. |
Originally Posted by maxxman04
(Post 194831)
Originally Posted by T.Neff
(Post 194858)
That book is a good ref for the uncle too.Well what you do??.Try to tell people from all too many yrs of doing this and if they decide it is too much trouble to take the time...................................LOL.
(Post 194831)
I'll bet money he doesn't know how to figure C/R's and from what he posted,isn't willing to learn.:rolleyes::rolleyes::rolleyes:
(Post 194831)
Originally Posted by kjape
(Post 195025)
I am not shure if that is my compression. I read somewhere that those dome top pistons is a -11cc on the heads (they actually where 75cc). Thats where i got that idea. I had those pistons just laying around and so did the 350 so i thougth about swapping my 305 in the monte carlo ss with a street/stip 350.
Dome pistons are not - numbers they are plus.A - would be a inverted dome.BTW-those smog junk heads are 76 CC.They do not flow worth anything.The reason and logic in - or + numbers is directly related to SCR's._ takes away from that and + adds to it.Deck height is also a factor needed to know to figure C/R as well as the head gasket. I am not guessing here.Not a internet hero.If you want help,your going to have to learn to swallow some of that ego bud.;) |
| All times are GMT -5. The time now is 9:34 AM. |
