GM problem wiring harness
Alright guys so my Aztek stop running while driving down the road. I had someone who works on vehicles check it out. They pulled the wiring harness and it was full of water and the fuel pump wires just fell out. I was just wondering what cars are compatible for a 2001 Pontiac aztek so I can get a wiring harness and connector for it. Thanks greatly appreciated.
I did one. the owner was going to put a fuel pump in it. the pumps wiring harness was corroded where it passes through the floor. The area is recessed so it traps and holds water. I ended up hard wiring in new wires putting the connection points further down the line; not where the water will be trapped.
if your repair is at the same pass through into the passenger compartment; putting in the same harness at the same junction point is a repeat repair waiting to happen.
the water wicks through the carpets down to the floor which sits above the factory connectors. a good laser cut floor mat that traps water would help.
Do you by chance remember how you hardwired it??
jeffwsi
K5 Blazer
August 12th, 2007 7:30 PM
