S-10 & Blazer 1982-2005
1995 S10 Blazer Headlight Problems
Old Jun 20, 2008 | 8:49 PM
jaybull's Avatar
Default 1995 S10 Blazer Headlight Problems
I have a 1995 blazer with problems with the headlights , the DRL's work but whe I turn on the headlights the they turn off if I flip the high beams on they work. I have located the relay in the glove box and pulled it out and swap it and no change I have left it out and noticed that the headlights work but the passenger side is normall brightness but the driver side is dim. The lamps are dual element. Please help it is driving me nuts and my wife
Old Jun 20, 2008 | 10:27 PM
EvansBlue's Avatar
Default RE: 1995 S10 Blazer Headlight Problems
You underhood fuse box. It sounds like you have blown the fuse for the right side headlamp. Check your underhood fuse box to find it. Its using the DRL mode on the right side to compensate for the inoperative low beam.
garyv990
Feb 11, 2015 9:52 PM
droppedmybeerdamnit
Nov 24, 2011 8:43 PM
1995Chevys4Life
Jan 15, 2011 12:54 PM
das1984
Jul 18, 2008 7:43 AM
RTillery
Jan 6, 2007 12:18 PM
