S-10 & Blazer 1982-2005
2002 S10 Crew Cab Fuel Tank
Old Jul 15, 2011 | 4:08 PM
dwgsp's Avatar
Default 2002 S10 Crew Cab Fuel Tank
My mechanic noticed that the fuel tank on my '02 S10 Crew Cab is close to rusting out, and recommended replacing it. However, he has not been able to locate a new or used fuel tank for my truck. Apparently the '02 Crew Cab model uses a unique fuel tank, that is no longer available from GM, and he also can't find an aftermarket fuel tank.
Does anyone know of a source for a fuel tank for my truck? I guess that my other option would be have the existing fuel tank sand blasted and then repair any weak spots, but I don't really like that alternative. Any other ideas will be appreciated.
Thanks!
/Don
Old Jul 15, 2012 | 10:35 AM
Bobbie Hoffman's Avatar
I have an 01 crew cab with the same issue. I found mine,when replacing the fuel neck. My tank looks pretty clean aside from about a thumb size rot hole where the metal tank neck connects w/ the fill tube.
I have not found any aftermarket options. So basically I have a vehicle that ive put a few grand into a vehicle after purchasing it for to damn much.Now im stuck thanks chevrolet! There are a ton of issues w/these crew cabs,unfortunately with something like this,you are kind of forced to deal with it,dump it, or probably trade it in as I don't want to screw over an unsuspecting fool like myself. Who would have thought you could'nt get a tank for a vehicle that was nine yrs old when i bought it.
BruceNewbauer
Jun 4, 2014 4:27 PM
dpainter68
Dec 7, 2012 10:22 AM
flash12
Dec 23, 2008 10:13 AM
mikewaterskis
22
Oct 10, 2007 8:47 PM
kc01976
May 17, 2007 5:53 PM
