S-10 & Blazer 1982-2005
4wd 2003 s10
Old September 4th, 2006 | 6:43 PM
s102003's Avatar
Default 4wd 2003 s10
i've been pluging away at my 4wd 2003 s10 because the front wheels aren't engaging when i press the 4hi/lo buttons. the l.e.ds in the buttons are solid (not flashing) and my transfer case seems to engage. i've checked the vaccum that is situated under the battery tray and works fine, i've checked the same cable that goes to the vaccum down to the transfer case and the vaccum line that seems to go to the back of the transmission. i've checked the electrical plug-in and seems to be corrosion free. the drive shaft turns all the way into the tranfer case (or at least it seems to) just nothing coming out of the front axle, only my rear wheels are turning. i tried turning the front wheels just with my hand and there is quite a bit of resistance. so i'm wondering if anyone has ever encoutered this problem in the past and maybe there's a fix/solution to this.
thank you
chris
Old September 10th, 2006 | 1:41 AM
kcb37's Avatar
Default RE: 4wd 2003 s10
If you have a book see if their is anyway to check the acctuator on the axle.
D Chevy
September 17th, 2012 1:06 PM
04Greg
March 2nd, 2011 10:46 AM
vpbho
November 1st, 2010 11:08 AM
waller2003
October 19th, 2009 10:49 PM
DianaT
November 29th, 2007 1:12 AM
