91' S-10 Blazer 4X4 tire pics
I have a stock 91' S-10 Blazer 4X4 and i am looking at getting some new tires. i am planning on getting bigger tires but i want to see whant they look like first. so if anyone has any pics of a stock blazer with 30x9.50x15 it would be awesome if you could post some pics on here. Thanks.
RE: 91' S-10 Blazer 4X4 tire pics
sorry mikey9776, don't have any pic's of my Blazer (don't even have the truck anymore), but i was runnin' 31x10.5-15's on mine. looked gr8-meaty, fat, tough. i had 30x9.5's on it b4 and wasn't too keen on the look it had-the tire's just looked too skinny for some reason, even though they were taller & wider than the factory 235/75-15's that came on the trucks. the only problem i had on my Blazer was that the outside edge of the tire would rub against the bottom edge of the inner fender well where it bolted to the actual fender. this only happend (often) when i had the wheels turned to lock (L or R), and had the suspension compressing alot, u know, while playing in fun stuff! the "damage" this caused was relatively minor. the tire polished this area, and slightly pushed it in a little. the suspension on my truck was stock ride height, so if your's is raised, u'd have no worries about goin' with 31's. u do realize that the more u increase the tire size, the faster your fuel mileage will fall.
I am looking at getting All Terrains or Mud Terrains would the larger tread design make a difference in your results with your. Like would it be worst with M/Ts
Stock size
These are 31's BFG - ALLT - KO's on my stock 94 s10 pickup
These are 33's that were on my 99 s10 blazer - 7 " trailmaster lift so not sure it helps but I still like the photo
Caper
December 4th, 2007 5:16 PM
