S-10 & Blazer 1982-2005
95 S 10 Timing belt
Old May 16, 2008 | 2:23 PM
HMiller111's Avatar
Default 95 S 10 Timing belt
I have a 1995 S 10 and I need to replace the timing belt. It has a tentioner and I asume it needs to be loosened. My question is if this is spring loaded or do I just loosen the 15mm bolt and then pry it back to tighten. It has alignment marks on the top. I have the new belt and would like to do this my self. Thanks
Old May 16, 2008 | 4:47 PM
EvansBlue's Avatar
Default RE: 95 S 10 Timing belt
Its a fairly involved process on this engine, but the chain guides should loosen with the wrench. I'm not sure about the older vortec, but the 97+ has a combination of spring and nut, so the nut has to be loosened to move the spring out enough to loosen the chain.
Old May 16, 2008 | 5:01 PM
HMiller111's Avatar
This model has a serpentine belt not a chaine.The tensioner lays on the belt and the bole is on the piece above. It looks like the bolt has to be loosened to move the tensioner.
Thanks Harold
landon101
22
Nov 14, 2021 10:48 AM
jmms
HHR
Apr 17, 2015 4:22 AM
OtherCarASaab
Aug 31, 2012 12:00 AM
hollijb
Feb 12, 2007 12:21 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
