S-10 & Blazer 1982-2005
ABS lights up, codes inside, which to do check first?
Old Apr 13, 2009 | 12:46 PM
pfsantos's Avatar
Default ABS lights up, codes inside, which to do check first?
Hello everyone,
I'm hoping someone knows these ABS systems well enough to help, because I'm lost.
I' ve checked for codes and get:
27, 66, 86, 12, 25, and sometimes 26.
When I reset the light, turn off, turn ign. on. (engine off) the system does its self test and returns with the same codes. I can hear the ABS unit turn on and off, btw. I've checked the front left sensor resistance and it checks out ok. Some of the other codes are related to the hydraulic/electric unit.
I know there's a particular order with which codes to takle first, but don't know this order. I've attached the two pages applicable with the codes listed. This is from a user's manual for one of those code retrieval units that plug into the diagnostics port.
Please help - I'd like to get this thing working if at all possible (I like a challenge).
Attached Thumbnails ABS lights up, codes inside, which to do check first?-abs-codes.jpg   ABS lights up, codes inside, which to do check first?-abs-codes1.jpg
Old Apr 13, 2009 | 1:22 PM
EvansBlue's Avatar
I'm thinking either the OBD is malfunctioning or the ABS unit needs to be replaced.
silverado 1500 2001
Sep 3, 2014 1:03 PM
SILVERAD01
Mar 6, 2009 7:11 AM
rif
Jun 13, 2007 9:12 AM
cowboys
Dec 18, 2006 12:28 AM
BinkysDad
Oct 24, 2006 11:32 PM
