S-10 & Blazer 1982-2005
battery draw: RDO BATT fuse is killing my battery
Old Apr 5, 2008 | 7:54 PM
rwrows's Avatar
Default battery draw: RDO BATT fuse is killing my battery
hey guys. i'm the proud new owner of a 99 s10 blazer and i have an electrical issue. my battery gets drained after a day or two. i've narrowed the source to RDO BATT circuit. when i pull the fuse, i get normal battery draw, but with the fuse in i get excessive battery draw. can anyone help me out?? thanks in advance.
Old Apr 5, 2008 | 10:50 PM
shawnvw's Avatar
Banned
Default RE: battery draw: RDO BATT fuse is killing my battery
There are only 3 things on that fuse, the radio, instrument panel, and electronic climate control module(if equipped). Put your fuse in, hook up your amp meter and watch the draw. Unplug the radio, watch to see if the draw drops. If it does, you're looking at a radio. If not, do the same for the IPC, and the ECC.
Old Apr 6, 2008 | 9:52 AM
rwrows's Avatar
awesome. that's what i'll do. how do i know if i have electronic climate control?? i don't think i have it because i just have a **** to turn to blue or red. also, what's the easiest way to unplug the radio? do i have to remove it??
Old Apr 6, 2008 | 12:04 PM
shawnvw's Avatar
Banned
Your climate ontrols will either be digital, or analog(just regular ***** to adjust), The best way to check the radio, is to accually remove the radio and unplug it
Newsom09
Dec 29, 2020 11:46 AM
Burgermeisteradam
Apr 2, 2015 12:14 PM
Ron Malinowski
May 29, 2014 11:03 PM
Matts10
Nov 5, 2010 8:19 PM
