Chk engine lite,,, always miss fire no 4...
MORNIN guys hope all are stuffd full of bird,, heres the run down , I blew my engine bought another used from SW engines said it was tested, so when I got it I had every gasket replaced to be sure so it has been opened up n clean thourghly, since ive had installed I keep getting the same freakin code miss fire no 4, this is what I have done, ngk plugs, ac deloco gold plug wire set, new distributor n cap... not sure what else? any ideas of such would be appreciated? thanks guys happy holidays THE MILKMAAN
2002 chevy s10
It's a 4.3 L V6 vortec, next step is a compression test, it runs great doesn't flutter when u punch it, it takes off, been talking it maybe the reluctor wheel?
You can check the pickup, should be around 1000 +- 200 ohms, also if you pull it, the magnet should be able to pick up a couple small screws. I doubt it's the ring.
Compression test
Having a 2nd compression test done, first one was then good but for some reason I'm still getting a po304 code... be honest I'm beginning to think my truck is simply possessed...will chk back...
