Fuel pump elec problem.
Wondering if any one has had this problem? My Blazer was running (warming up) I came back out and it had died. The next day I checked the fuel pressure, zero. I jumped the relay and the pump still wouldnt come on, I even tried banging on the tank (it worked before to get it driven on a trailer) nothing. This now my second pump the first one went out two years ago. So I replaced the pump again. It started right up, then the next morning it wouldnt start. i kept cranking (key on and back off) then I heard the pump come on and it started. So I drove to the gas station to put gas in it since it was low. When I came back out same thing. Only this time I pulled the relay again and jumped it and the pump ran and started. I put the relay back in restarted it and drove it home. Now it starts and runs fine. My problem is this is my wifes vehicle and I dont trust it to haul my kids or get me to work. I dont know if it is the ECM/ECU or some sensor, maybe a ground? The new pump also has good pressure(I checked it with a gauge.)
I did some more checking And cant get the problem to repeat. The fuel pressure is good and holds. I looked at a wiring diagram and the oil pressure switch is in parallel with the relay so if the pressure drops it cuts out the pump. so I unpluged the oil pressure switch and it still starts and runs? but if I pull the fuel pump relay it dies, I dont understand? wondering if 98 blazer is wired different. I know it doesnt have a prime connector. I spent awhile looking for it. Wondering if the PCM is the problem? The next step is going to be checking for loose wire under the fuse block?
hunter10220
May 18th, 2011 8:37 PM
DennisT
August 12th, 2007 1:59 PM
