S-10 & Blazer 1982-2005
Harmonic Balancer Installation
Old Apr 27, 2012 | 1:34 PM
klturi421's Avatar
Default Harmonic Balancer Installation
I am getting ready to install my harmonic balancer and was curious. Is there supposed to be a gap between the balancer and the crankshaft seal? I didnt look at my other one before I removed it and have not seen any information regarding a gap.
Old Apr 27, 2012 | 8:55 PM
RacerX's Avatar
Should be a minor gap not to rub against the crank snout and timing chain cover. Lube up the center before you slide it on so it moves freely against the snout and then use the center bolt to drive it down and hold it on.
Old Apr 28, 2012 | 9:57 AM
Camaro 69's Avatar
Site Ambassador
First off, use the proper installation tool to pull the harmonic dampener on. I've known of too many guys who used the center bolt to try and pull it on, only to pull the threads out of the crank instead, or snapped the bolt off. Then you'll have a whole new question to ask here! AutoZone has the tool in their free tool loaner program.
I'm not quite following you about where the gap is. If you mean between the rubber seal and the seal surface of the dampener, no there shouldn't be a gap. If there was, you'll have a terrible oil leak.
Old Apr 28, 2012 | 6:00 PM
RacerX's Avatar
Wow! I ve never heard of that. Pulling the threads off the crank? But I guess anything is possible. Ok, sure Autozone has that tool for $45. Wow, and I ve been doing it Caveman Style for so long, dang. Haha!
Didnt ask, but did you replace the front oil seal and timing chain also? Water pump also since it is all easy to do it now and at once. It doesnt say what you did overall to the motor so I m guessing you are doing a rebuild?
klturi421
Apr 27, 2012 8:38 PM
Daga
Mar 19, 2012 10:17 AM
irving216
Jan 31, 2012 2:38 PM
4wheelR
Feb 12, 2008 3:20 PM
Slimmurph12
Apr 20, 2007 11:50 AM
