S-10 & Blazer 1982-2005
Hesitation and misfire in cylinder #4
Old January 16th, 2021, 2:49 AM
  #11
zadigofla's Avatar
Might be able to determine that with a vacuum gauge (seems like no one uses those anymore), unless that's the gauge the mechanic used. Yeah, the distributor bearing going out is something I've never seen before, but sure, it could do this. You learn something new every day in life. Might have a small intake manifold leak. I've seen people actually spray gasoline on the manifold to test for leaks, but something less flammable, like WD-40 would work as well, IME.
I've heard of people using different substances to clean a catalytic converter out, like Methanol or Acetone (don't use without gloves and a filtered face mask as these can go right into your body though the skin), but I've never seen it done for myself, so who knows?.
UPDATE 3
So unfortunately the cat is clogged. The distributor was definitely the cause of the misfire but the sputtering (my main issue) was caused by all the back pressure from the cat. My mechanic said it was like trying to breathe while being strangled. He tested it without the upstream o2 sensors and said it ripped. We’re going to flex pipe it temporarily until I can afford a new cat. This Sunday I’ll be helping him install the new distributor.
Old January 16th, 2021, 4:24 AM
  #12
oilcanhenry's Avatar
Originally Posted by zadigofla
UPDATE 3
Yeah, Cats are not cheap with the platinum, palladium and rhodium metals used in their manufacture. Thankfully they don't use Gold, ain't it?
As to cleaning it, is your vehicle burning much oil? You don't want that Cat clogging up again. Sometimes, oil consumption can be lowered with a new set of valve seals, as they do get hardened with time and mileage and can let too much motor oil into the cylinders.
Ron6519
March 7th, 2020 9:15 AM
mm66
February 8th, 2020 5:05 PM
Coreyf
1988 - 1998 (GMT400)
May 25th, 2016 11:15 PM
tng196664
March 9th, 2015 8:09 AM
TahoeMatt
11
February 6th, 2012 7:15 PM
Quick Reply: Hesitation and misfire in cylinder #4
