how big can i go with my tires? 215/75/15 on a 83 s10
Given the clearances I see, you probably could increase a couple more sizes, but...
Keep in mind, that the best performance is realized when the width of the tread and the width of the rim are the same. Otherwise, when you put a wide tire on a narrow rim, it creates an oval, and can be quite "wobbly" and several other performance features are compromised as well.
Are you 4WD ?
Yes, very well maintained.
Offroading...ok, but emphasis on what type terrain ?
Are you 4WD ?
http://www.discounttiredirect.com/di...ngler+DuraTrac
This is the tire i decided to go with i stepped up to a 235 instead of having 215.
This will meet my expectations for offroading/snow
For what kind of off roading? Occasionally going up the state game lands Rough terrain (like extremely rough) mudding ETC...
And yes 4WD
Annd thank you for trying to help and if you have anymore suggestions please let me know. Thank you for caring.
And yes 4WD
Keep in mind, that the best performance is realized when the width of the tread and the width of the rim are the same. Otherwise, when you put a wide tire on a narrow rim, it creates an oval, and can be quite "wobbly" and several other performance features are compromised.
