How can I dismantle the front blinker Chevy S10?
Hi,
I have some water in my left front blinker and I want dismantle to dry it. The car is a Chevy Blazer S10 ZR2 from 2000. Can anybody help me, how I take off this Blinker? Greets from Germany Jens |
Originally Posted by woopee
(Post 106027)
Hi,
I have some water in my left front blinker and I want dismantle to dry it. The car is a Chevy Blazer S10 ZR2 from 2000. Can anybody help me, how I take off this Blinker? Greets from Germany Jens If you have owners manual - follow directions to remove the headlamp assembly (basically pulling two black plastic retainers straight up). This permits access to rear of the parking lamp/turn signal/fog lamp housing assembly. The housing is held in place by plastic "ears" on side nearest center of vehicle and with a longer "finger" on side nearest side of vehicle. Both retaining devices are easy to see (using flashlight) and simple to release (pinching the ears and using flat-tip screwdriver for the other). You can then gently pull the housing out from cavity to disconnect the turn signal/parking bulb (press small plastic tab and rotate - will only turn one way) and fog-lamps (if installed) by lifting connector tab to slide off the bulb. The above information might seem complicated but once headlamp has been removed it becomes intuitive - more or less. Did you drive through water deep enough to flood the "blinker" Assembly? If not, make sure the gaskets for the fog-lamp and blinker bulbs are intact and seal correctly with the housing. |
