S-10 & Blazer 1982-2005
How can I dismantle the front blinker Chevy S10?
Old Jul 18, 2009 | 4:01 AM
woopee's Avatar
Default How can I dismantle the front blinker Chevy S10?
Hi,
I have some water in my left front blinker and I want dismantle to dry it. The car is a Chevy Blazer S10 ZR2 from 2000. Can anybody help me, how I take off this Blinker?
Greets from Germany
Jens
Old Jul 18, 2009 | 9:24 AM
far2grumpy's Avatar
Originally Posted by woopee
Hi,
Greets from Germany
Jens
I have a 2004 S-10 which is probably very similar.
If you have owners manual - follow directions to remove the headlamp assembly (basically pulling two black plastic retainers straight up). This permits access to rear of the parking lamp/turn signal/fog lamp housing assembly.
The housing is held in place by plastic "ears" on side nearest center of vehicle and with a longer "finger" on side nearest side of vehicle.
Both retaining devices are easy to see (using flashlight) and simple to release (pinching the ears and using flat-tip screwdriver for the other).
You can then gently pull the housing out from cavity to disconnect the turn signal/parking bulb (press small plastic tab and rotate - will only turn one way) and fog-lamps (if installed) by lifting connector tab to slide off the bulb.
The above information might seem complicated but once headlamp has been removed it becomes intuitive - more or less.
Did you drive through water deep enough to flood the "blinker" Assembly?
If not, make sure the gaskets for the fog-lamp and blinker bulbs are intact and seal correctly with the housing.
Got Options?
Jun 20, 2013 10:24 AM
skullchurch
Aug 8, 2012 5:13 PM
Brandonion1985
Jul 20, 2011 5:40 PM
chriswf
Feb 21, 2008 5:03 AM
pRiMo1
Colorado
Nov 6, 2006 11:30 AM
