HP Curious
HP Curious
I have an '04 Blazer with the Vortec 4300 V6 in her. im curious about increasing my HP and Fueld Efficiency.
I know i can add a cold air intake, an electric fan, and a throttle body spacer, and i know a port and polish would help too.
Im wondering if there's anything else i can do, such as super chargers for example or anything else.
Thanks for the help.
Ahkala-
Ahkala-
RE: HP Curious
yes you can SC, but depends how much power your going after, and how reliable you want it. if just toughining the truck up, I suggest basic mass airflow, TB, Exhaust(headers for more) minexpand cat back pipes and add a magnaflow or flowmaster will improve both power and fuel effic. K&n or green for a little extra as well. there are also chips available but not much gain.
RE: HP Curious
If you are looking major power, just do a google search for Rear-mount turbo blazer. There are guys all over the net that have done it.
RE: HP Curious
If you want something you can just screw around with on the daily commute to work, I would suggest doing the usual intake/exhaust/headers setup. A port and polish is quite pricey, and for that money you could find some free-er flowing heads off ebay or your local performance shop. Also upgrading your spark plug wires and putting in diamond fire spark plugs will increase fuel efficiency.
If you want full out raw power, I suggest doing a new cam, definitly do heads, and a small turbo such as those on the Syclone/Typhoon.
Best of luck, and if you do anything radical, please post pics!
RE: HP Curious
This may sound unrealistic but you could do the 350 swap. You could even pickup a whole 95' Caprice for around $1500 and donate the LT1 to your truck and still get around 22mpg.
harascho
May 10th, 2009 8:26 AM
blackvmax01
July 28th, 2008 11:12 PM
guvner
June 30th, 2008 9:07 AM
