Leaking fluid
Leaking fluid
Daily occurrence it used to only do it while on an incline but now even while parked flat and it’s red tranny fluid but I just can’t locate where it’s leaking from
nice pics of yer driveway/curb, but not a single one of the underside of the truck....I find it hard to believe w/a fluid leak THAT massive, u cant find the source...get the truck on jacks n get really under it-grab a couple of cans of brake cleaner spray-spray every oily spot u can see under the truck until clean...do this when not goin to drive it...come back 12 hrs later n see if u find fresh fluids in areas on the TRUCK, not the ground
First, it's be helpful to identify what fluid it is, that way you can have a general idea of what area it could be coming from. If it's oil, one thing people forget to check is the oil sending unit that runs up to the oil filter. (If you have an isolated oil filter rather than an engine mounted one) clean your oil and trans pan, check for cracks in the pans and check for breaks in the seals.
tbb2
13
August 4th, 2015 10:55 AM
